Stupid mistake when deleting old iphone... ugh
Rochester, MI, US, World
Got around to activating my iPhone 17 Pro today. Loving it so far (coming from a 13 Pro). However, the setup did not go as planned :rolleyes: The new phone set up easily, got everything from my iCloud backup, transferred the eSim to my new phone, etc. Standard new phone stuff. I then went to prep my old phone for trade-in my turning off 'Find My' and deleting it from my iCloud account. Should have worked great, except... i forgot that when you restore an iCloud backup on a new device, the old device name transfers to the new device. So I see a device in my list that says 'iPhone 13Pro' and delete it. A couple minutes later, my new iPhone loses its cellular connection, then reboots. After some time, it goes to the initial setup screen. What?! Turns out, I deleted and reset my new phone.
Eventually, I realize my mistake and simply go thru the initial setup again. Unfortunately, I can no longer transfer my eSim since it already transferred once. Can't do it via the T-Mobile app either. So using my wife's phone, I call and get someone who was able to take care of it (after a long search of finding my account PIN :whistle:). Wait time was supposed to be an hour, but ended up getting settled in about a half hour. My new phone is up and running. Lesson learned. My 13 Pro was rock solid for so long, so it had been awhile since I went through this process. All's well that ends well I guess.
What if that happened from Android to iPhone and vice versa? It could be even worst?!?
  • Like
Reactions: Arc
Some companies won’t use Android …
This issue wouldn’t really have changed with a different OS. It was my fault that I didn’t double check before deleting the ‘old’ device. Next time I’ll just do it as I always have: wipe the phone from the phone itself. T-Mobile was adamant that you use iCloud to do it, and I wanted to make sure I got my trade in money back, so I followed their instructions to my downfall 😂
Still a very favorable impression of the 17 pro I assume?!?!
