- Joined
- Aug 21, 2024
- Messages
- 5
Hello all. I have a 42 inch club cadet with a 22 hp 7000 series Kohler engine. There are two problems. The first problem is the engine surges, especially when there’s no load on the motor at lower RPMs. I have replaced the carburetor, spark plugs Fuel filter pump gas lines after the fuel filter and it’s still surges. The second issue is after 20 minutes of cutting the lawn the lawnmower dies. Just recently after it died, the engine would not turn over. I replaced both coils it still dies. There may be an issue with the charging system as I’ve already replaced the battery once in the last 12 months , I read an earlier thread that may be related to low-voltage as this model has a cut off switch for the seat. Does anyone have any suggestions?
