Do what ? Maybe the dripping handle in the 2nd image ? Try tightening the nut behind the handle first.What is the best way to go about this for a DIY? Or is it too risky?
Start by trying to remove them with a good pipe wrench with sharp teeth on the biting jaws. Be sure to hold the faucet from flexing with a wrench or Channel lock pliers applying counter torque. If necessary, apply some heat with a propane torch on the hose coupling, but don't heat the faucet too long since it may melt the rubber washer.My fault - how to remove a stuck water hose*.
So I did some research and found some say to use a torch and some would use a hack saw and slightly cut the head then remove with pliers.
Thanks for all of the suggestions.
I think the easiest and fastest way would be to split the thin wall hose coupling with a hack saw.Start by trying to remove them with a good pipe wrench with sharp teeth on the biting jaws. Be sure to hold the faucet from flexing with a wrench or Channel lock pliers applying counter torque. If necessary, apply some heat with a propane torch on the hose coupling, but don't heat the faucet too long since it may melt the rubber washer.
If all else fails, you will need to carefully split the thin wall hose coupling with a Dremel tool and peel it off the threads.
You won't get a hacksaw in that space. Use a Dremel (if you have one) like Nukeman7 said.I think the easiest and fastest way would be to split the thin wall hose coupling with a hack saw.
i have done about a 100 of these with a hacksaw takes about a minute at most..just come down from the top.split it. of it comes.You won't get a hacksaw in that space. Use a Dremel (if you have one) like Nukeman7 said.
If you have a 2nd person (ideally) and a pipe wrench, try that. The 2nd person is for holding the faucet so you don't break it.
I never considered a hacksaw design like that. 100 times ?i have done about a 100 of these with a hacksaw
I'd try clr or lime away to get rid of the hard water and corrosion first.What is the best way to go about this for a DIY? Or is it too risky?
I used a hacksaw like that to cut closet bolts on a new toilet install in a flip. Had no room for for a normal hacksaw.I never considered a hacksaw design like that. 100 times ?
I got one off yesterday. But the cold side hose will not bulge. It's time to cut it off.Split the coupler with a hacksaw, spread the split with a screwdriver. Of course penetrating oil soaking on it while you saw.
I've done hundreds of them in my years of being a washing machine tech. on service contract units.
Yep, until the old hose blows, flooding your basement.I got one off yesterday. But the cold side hose will not bulge. It's time to cut it off.
My friend suggested to buy a union connector and connect in between the old hose to the new hose. Do you think that would work?
