- Joined
- Jul 10, 2022
- Messages
- 5,918
Over the lives of the cars I've owned, usually a leaking shock or strut became known to me during a state inspection.
When I was having my front/upstream 02 sensors done last fall, the indie shop showed me my right front strut had begun to leak. 2006 LS430. 133k
I actually asked the tech if he could wipe it since I was having a state inspection literally when the 02's were done, he said sure. I discussed with the owner about replacing all 4, and he said yes, I would do them sooner than later, because the sooner you do them, the more you'll enjoy the ride. meaning the logic is the car is old, so maybe these will be the 2nd set and last set for the vehicle. Before the state inspection, I pulled the wheel to look, and saw no oil at all. Passed inspection.
Flash forward, I noticed an oil spot under the car, and curiously, rear right. Jacked her up, thought oh no, rear diff? Rear axle? No, rear strut.
I bought 4 KYB Excel G's for the car, and will get them installed shortly.
Question: Since there is no longer any oil being left on the driveway etc., has "all" the oil leaked out?
The ride does not seem to be any worse off, why?
I remember in the old days, if a shock failed, the vehicle would seemingly bounce forever, because the springs are not dampened any longer as they should be.
From the above, I want to say that all of my cars have had shocks/struts fail, none have had rides deteriorated in a noticeable way, and all were replaced due to a state inspection.
I wonder if this has anything to do with the ride seemingly to be unaffected?
"an internal, anti-rollover spring (may cause extended length to appear shorter)"
I googled it for some sort of explanation....
https://www.monroe.com/technical-resources/servicegrams/internal-rebound-springs-strut-length.html
What do you folks think?
