I just removed my strut assembly on my 98 Sentra. When I attached the spring compressor to the spring, I left the top and bottom coil free. After I removed the piston rod nut off, I took the spring off the strut and the top and bottom coil (no compression) was in the same position as the piston rod nut was on.
My question is shouldn't the coil be lossen up without a compressor?
