Strut replacement
Changing struts in my old Corolla was my first use of my new battery powered impact wrench. Highly recommended if you don't already have an impact. Four or 5 uggas on the bottom bolts and you should be good to go.
  • Like
Reactions: wlk
Nah, just added some thread locker and a 1/4 turn more, they won't come out. Don't remember ever torquing a strut/shock ever and never had one budge before.
Now if an excuse for the wife, yes need a tool dear! ;-)
I can't say i've used a torque wrench on strut bolts. Usually a breaker bar to get it good,n,tight.
The bolts on my WDH called for 380+ ft-lbs.
I've never used a torque wrench on them. I use a breaker bar and tighten them good and never had an issue. Torque to 150 then use a breaker bar and give it some more. Are you compressing and reusing the springs. if not don't be upset the ride becomes harsher if not awful. The factory springs are nice riding. The ones that come in the assembly have always been harsh riding I no longer buy them just the strut and change them over. Unless they're very rusted or have collapsed and ride low I'd always reuse them.
When we just did the front end of an '03 Astro AWD he kept asking me, "Does that have a torque spec?"
I kept telling him I'm sure it does, but I don't care what it is (he trusts my judgment). Even on tie rods -- at least in steel knuckles -- it's Gutentight plus more until the cotter aligns. The two things I always torque are axle nuts and lugnuts.
I'll say that strut-to-knuckle bolts are not highly sensitive fasteners unless there is a camber bolt involved. However, if they do see a lot of rust/corrosion so if you tighten them using your favorite high-power 1/2" gun and give it the full beans, they might be extremely hard to remove next time once corrosion is factored in.
  • Like
Reactions: D60
218 lb ft huh? I know I am only 140lb so if I have a 3 ft breaker bar and a bathroom scale, I can stand on it with one foot and the other step on the breaker bar tightening to the right weight.
218/3 = 72.66lb. 140lb - 73lb = 67 lb. So I need to watch my bathroom scale go from 140lb to 67lb slowly.
Same for those 380 lb ft bolt, 380/3 = 126lb. 140lb - 126 = 14lb. So I need to watch my bathroom scale go from 140lb to 14lb.
That’s uh…one way to do it… :unsure:
Amazon has some that go to 250. I got one on Prime Day. They are also good for axle nuts that also have high torque values over 150 lb ft.
But for those strut bolts, you can just tighten that as much as you want, or if you have an impact gun, zip them in :D
