Installing new struts on our 2015 Toyota Avalon XLE with 114,000 miles on the car. Looking up torque specs for the two large bolts on the bottom of the struts. 214 foot lbs! My torque wrench is 150 foot lbs. Time to come up with a new wrench.
Nah, just added some thread locker and a 1/4 turn more, they won't come out. Don't remember ever torquing a strut/shock ever and never had one budge before.
Now if an excuse for the wife, yes need a tool dear! ;-)
This is what i have.
https://a.co/d/0gXsw5Kh
Are you using a torque limiting extension and impact driver? I would hate to do that by hand.The wheel bolts on our large tractors call for 450 ft-lbs, makes torquing the wheels a tiring process at 20 bolts per! 40 each if it's a unit with duals and hub extensions.
Nope, they get run down tight with a Milwaukee 3/4 and torqued by hand with a long extension (if necessary) and a big ol' 3/4 torque wrench.Are you using a torque limiting extension and impact driver? I would hate to do that by hand.
218 lb ft huh? I know I am only 140lb so if I have a 3 ft breaker bar and a bathroom scale, I can stand on it with one foot and the other step on the breaker bar tightening to the right weight.
218/3 = 72.66lb. 140lb - 73lb = 67 lb. So I need to watch my bathroom scale go from 140lb to 67lb slowly.
Same for those 380 lb ft bolt, 380/3 = 126lb. 140lb - 126 = 14lb. So I need to watch my bathroom scale go from 140lb to 14lb.
