I sort of always felt that weed eaters are more trouble than they are worth with the string wearing out. I just got a new trimmer. It is the a Poulan from Walmart and the best one they had running about $110.
The trimmer actually runs very good and starts easy without needing much choke or many pulls.
It's 33cc 2-stroke, has a straight shaft and a fixed line. The line is like .115" thick and comes in short section and is replaced as it wears out. Which is quite often. I went through about 2 or 3 lines in a few minutes trimming around some things. But from using some other peoples' trimmers that have a spool and the spool never feeding right and the thinner line I though the heavier fixed line would be less trounble. Not really sure.
I also looked at the trimmers at Lowe's and they were more expensive, but didn't particularly seem to be better quality. They had the brands Troybuilt (which I don't think much of) and Husqavarna who I believe makes Poulan. They also has several 4-strrokes. The little ad poster said, "Quieter, more fuel efficient, no mixing oil, cleaner..". I can believe all that, but even claimed more power and lighter. I'm not sure I buy that.
What's others' opinion on fixed line vs. spool, straight shaft vs curved, 2-stroke vs 4-stroke, etc?
