Oh, I like it too. What a huge load of baloney that is.
A sample size of one, with words like "could not be established" and "believed". Really? You could not establish that hydrodynamic boundary layer failure caused the damage? Really? What kind of testing facility are you then?
Worthless except as a sensational statement.
Originally Posted By: A_Harman
I really like the part where they describe what happened when they tested a heavy duty diesel with an oil having HTHS of 2.6:
"While the exact sequence of events leading to the engine failure could not be established, it is believed that excessive wear in one of the crank assembly components resulted in sezure of the crankshaft, causing it to break and exit from one side of the engine body. However when the same engine test was run using SAE 15w40 using the same additive technology an excellent passing performance was observed."
Here's a sobering warning about the relentless pursuit of thin oil. What else should they expect, considering they were running 2.6 HTHS oil in and engine designed for 3.7 HTHS? The elegance of hydrodynamic bearings is there is no metal to metal contact when the system is working as designed. By putting in thinner oil than the engine was designed for, they pushed the system out of its designed regime. So now the engine bearings need to be redesigned to work with the thinner oil. Talk about the tail wagging the dog...
