Strange Spark Plug Phenomenon
not Sweden
I own a Husqvarna R322T AWD Rider with a 22hp B&S engine. I replaced the spark plugs with stock Champion RC12YC plugs last fall. Briggs says on their website that their torque spec is 7-15 ft. lb. of torque (which is 84-180 in. lb)
They make sure to note that 15 ft. lbs. is the MAXIMUM torque that can be used, but imply that if one can use less... then use less. When I installed the plugs, I didn't know about the 7-15 range, and so installed them with a torque wrench at 180 in. lb. (the full 15 ft. lb.)
Right after installing, the engine began to smoke at start-up quite a bit. It wouldn't continue after it ran for some time, but it was noticeable, and wasn't there before I changed the plugs.
So, I undid the new plugs, and re-torqued them to 120 in. lb (10 ft. lb.), and now all the smoking on startup has gone away... it's just as it was before the new plugs were installed.
So why did that happen? I didn't over-torque the plugs at 15 ft lb, or damage the threads, but clearly that extra 60 in. lb. made some difference that caused the smoke. Anyone know why?
More than like likely your 90 degree plug wire boot was not pressed on one or both of the new spark plugs correctly after your first install before you re-torqued them
the torque spec is there so some knuckle dragger doesn't rip the threads out of the cylinder head by using a breaker bar to snug up the plugs. Chances are either you didn't have the plug boot on all the way or for some reason the plugs indexed at just the right point where the spark was partially shadowed from the fuel mix (pretty unlikely on a carb'd motor) and you weren't getting very good combustion till things warmed up.
I'd go with this reason
Good Diagnosis !
Torque spec does affect the heat range of a plug if it uses a washer/gasket. That would have no effect on a cold engine, only one at operating temp.
I agree with the plug wire not being on right- good call.
