How to compare mowers rated in HP vs ft-lb
the article i listed has a mistake. they say james watt invented the steam engine. this is wrong, james watt made big improvements in steam engines. i ll bet if you looked up the name james watt you will find the truth.
Originally Posted By: Cujet
Originally Posted By: morris
no one horse power is. a horse pulling 33000 ibs straight up one foot in one minuet. ie a ft lb is a measure of energy at one instant. a horsepower is energy over a time frame. check out www.web-cars.com/math/horsepower.html
Exactly. And hence the ability to do work.
they are the same amount of work...
1 ft x 33,000 lbs is the same amount of work as 1000lbs up 33 feet.
Work = force x distance
you are both correct.
I'll say it again, compare OPE engines based on displacement. It's the best way to determine real world power.
Yes, there are some differences between flat head and over head valve engines. Might want to give the OHV engine a slight advantage in power at any given RPM.
Even so, when comparing OHV mower or generator engines, compare by displacement.
