Strange Running Issues
MA, Mittelfranken.de
Engine had occasional high misfire count, high knock counts and at other times nothing. I decided to scope the CPS but saw it was leaking oil so for $15 for a Bosch new one its getting replaced.
They couldn't get the O ring in so the ground it down with a dremel and tossed the O ring and used some RTV. The RTV finally got eaten away and the thing was loose in the hole. How not to install a CPS.
People call it Euro trash but this is the sort of hack crap I see on a regular basis.
Dear gods above. It will eventually happen but...
When it does?
Send pictures of the wheel hub bearing job someone will do with a hammer when they don't have a press. Or at least, sensibly draw the hub on with the fastener hardware. ^.^
I watched a redneck buddy of mine do just that until the center race popped out and spilled the bearings out like a grandmother drops dentures. o_O
"Uhhh, yeah, hey there? Do you have the bolts that came out from behind it around here somewhere?" *bang* >...(clatter)
Ah, Florida. 🤪
