What are your thoughts on straight grade oils?
From what I understand, a straight grade SAE30 is much thicker at start up than its multi-grade counterpart, but it's more durable for extended periods of time because it contains no viscosity index improvers.
Also, a 10w30 is actually a 10 weight oil that is built up to become a 30 weight oil at operating temperatures. This will reduce start up wear and improve fuel economy during the warm up period.
A straight 30 weight will maintain it's viscosity better over extended periods of operation because it will never shear back in grade with the absence viscosity index improvers.
The ideal multi-grade oil would have viscosity index improvers that never wear out.
