My father owned an auto parts store and small repair shop in a small southern town when I grew up. I remember him using the old paper blue cans of STP as an assembly lube when rebuilding engines.
I once had a Bronco with a 300 I6. I used it for mudding and playing around as a young adult. In a mud hole one day I turned way too may rpms and unknown to me at the time, I broke number 3 and number 4 piston skirts. Anyway after the incedent the engine started throwing oil out of every gasket and hole it had. I started adding STP, the old blue stuff, to thicken the oil and slow the oil flow out of the engine. It worked, but eventually I must have been using mostly STP and no oil, the engine started knocking from the bottom end. I was living in Virginia at the time, in the Army. I took leave, bought two cases of Castrol 20W50 and a case of STP and headed home to Louisiana to rebuild the engine. I made it home, using nearly all of my oil and 10 cans of STP. I acutally spent more on oil and STP that trip than gas. Gives new meaning to"filler up with oil and check the gas". I had to stop every hour or so and top up the crankcase. The trip took nearly 24 hours, but I made it home, rebuilt the engine and returned to active duty in Virginia with no futher oil use and no further use of STP.
