STP S 6607 CUT OPEN
In the shop
This filter and unknown oil on a 22’ Nissan Armada at work. 9k on the last oil. Looks like lots of cold weather and moisture happened here. Most of the label was ripped off as had to use hulk strength to remove the filter.
That filters performance is synonymous with Frams top tier products in every way except price..... thanks for the c&p Adam
A6607 size can, too small for that V8 engine - but it didn't rip. A tough lil' bugger.
I would try a 4" long Baldwin B1431 that was discussed a couple days ago in another thread. See if it fits.
Anything in the way near the dome end that would interfere?
Thank you sir for the c&p!
Dunno the filter works fine. We use the 51358 and 57356 PROTECS on Nissan at work without issue.
It appears they changed bypass design and went away with metal crimp to hold media together. This is STP extended i bought 2025.
