Any puddling in the intake will cause that bog down. CRC will easily stall an engine, and you'll have misfires and detonation with matching CEL. I haven't found a manifold that would cause a hydrolock situation yet. Eventually, there will be an owner that fills his air filter box, ripple tubing, intake manifold, or Helmholtz resonators with too many ounces of the 'product'.
I do definitely shut down and let it soak for a couple hours. Stuff is useless if you simply blast it out the tailpipe, aka airplane sky writing poured Seafoam style.
And, after soaking, take it on a long gentle ride until the IVD product's 'puddles' blow by and evap on their own. Biggest mistake is to drive like a teenager with the pedal down sucking up all the 'puddles'. The solvent IVD cleaners, like any high btu low octane distillate, can cause detonation or even blow your engine with preignition. Really don't want a mega load on the engine when a teaspoon or 2 get sucked from some ripple intake tubing or variable manifold puddling place.
To help alleviate the distillate solvent btu/octane issue, if you're an 87 octane user, I recommend filling up with premium with the tank 'before' the spraying. Good time to throw in the PEA based cleaner to start the CC/piston/injector cleaning.... less detonation causing crud in the engine prior to 'spraying' the IVD cleaner.
