Normally I change out all fluids after the season and store everything dry for the winter. I added fresh pump oil and engine oil to my Honda Excell pressure washer this past spring but I only used it twice for a total of about 2 hours. Should I drain the fluids again for winter storage or keep them and use again next summer with out changing fluids? I fear they will go bad during the winter and possibily get moisture in the fluids?
Also should I be adding antifreeze to my presure washer pump? I have not in the past and all seems fine. My garage is not heated so it can get pretty cold but I'm not sure the water in the pressure washer can freeze?
