Sticking parking brake
Greatest Earth on Show, UT
I have rarely used the parking brake on the Burb but just moved into a place with a steep enough driveway that it is now used on a daily basis. The problem I am having is that the parking brake is not fully disengaging when I pull the brake release lever. The parking brake pedal pops up, but when I start to drive away, I can feel some resistance from the parking brake still being partially engaged. Once I get about 100-200 yards down the road, I can hear and feel the brakes finally fully release (kinda pops) and I begin rolling much easier.
Is there some sort of adjustment I need to do?
Sounds like it may have some contamination build up from not being used. I'd try driving around 20mph and applying the parking brake several times in a row to see if that took care of it.
If it still sticks, inspect the linkage/cables underneath the vehicle to see if there are spots where they are not moving freely.
+ 1
And if you decide to get underneath to inspect the lines, have someone engage and disengage the line to see how it's moving if it's not immediately clear.
I had those same symptoms on my Mazda 3. I caught it in time so that the cable wasn't frozen solid. Basically the linkage that is exposed to elements started losing its protective coating and was a bit rusty. I cleaned everything up and lubed the cable with some chain lube and everything went back to normal.
