Stick with WSS-M2C946-A?
Ohio
Hello, first post so be easy on me.
Simple question. The 2012 F150 Ecoboost requires WSS-M2C946-A but can the WSS-M2C946-B1 be used?
If so, I assume that A couldn't be used in place of the B1?
Read several threads discussing these oils but couldn't seem to find the answer.
to BITOG!
Here is what Ford lists each as on their service info site. To me it looks like the B1 can be used in A applications but I'll let the Ford folks answer.
Motor oil (U.S. and Mexico): Motorcraft® SAE 5w30 Premium Synthetic Blend Motor Oil XO-5W30-QSP WSS-M2C946-A
Motor oil (Canada): Motorcraft® SAE 5w30 Super Premium Motor Oil CXO-5W30-LSP12 WSS-M2C946-A
Recommended motor oil (U.S.): Motorcraft® SAE 5w30 Synthetic Blend Motor Oil XO-5W30-QSP WSS-M2C946-B1
Recommended Motor oil (Canada): Motorcraft® SAE 5w30 Super Premium Motor Oil CXO-5W30-LSP12 WSS-M2C946-B1
Originally Posted by BlueFog
Simple question. The 2012 F150 Ecoboost requires.....
Simple answer: Any good quality 5w30 or 0w30 oil that meets current API specs
The M2C945-B1 will work fine also SN+ is a great oil. I use Mobil 1 that meets these specs in my 2016 and 2018 ford fusion 1.5 Ecoboost.
I have been using Mobil 1 for years in the truck.
Went to pick up supplies for an oil change today and seen the store carries Motorcraft oil also.
Seen that it meets the B1 specs but didn't say anything about A.
Wasn't sure if it would work or not so got the Mobil 1 though the Motorcraft was $8 cheaper.
