sounds like it may take around 2 hours just to check everything, probably 10 hours to fix it all (for someone who has never done it), will I need a spring compressor for the struts, or would I not be removing/replacing anything they are connected to?
this is what I've compiled so far, couldn't find a couple things you mentioned, everything is x2 I assume
Lower Ball Joint (now they say no upper req, doesn't list any side specific parts so must be for either side) - DURALAST FA2084 LLT $24.99
Bushing, Strut Rod - ENERGY-SUSPENSION
Black 16.7106G $30.99
Stabilizer bar bushing - DURALAST
Front suspension FA7375 $9.99
Tie Rod End - DURALAST
Outer ES3332 LLT $21.99 driver side
Outer ES3332 LLT $21.99 Passenger (right side sitting inside vehicle)
total $177 + tax (15.57) = $193
