Hi,
my Volvo S40 has always had a light steering but now this is really driving me crazy, especially on highway. The steering is excessively sensitive to road inclination and always pulls strongly to the side of the inclination (which means most of the time on the right). On straight line the steering really feel loose and light around center, especially on highway, but with speed it also vibrates sometimes. Driving the car is really not a pleasure, it's always about countersteering and adjusting. When driving to a stop light once, the road was slighty inclined on the left and the car pulled a lot to the left. If you remove the hands from the steering wheel it would turn for 1/4 circle just because of that pull!
I have checked and changed most of the parts:
- tire pressure OK
- alignment OK
- wheel balancing OK
- front lower arms (including balljoints) renewed
- tie rods/balljoints renewed
- front suspension (shock/springs) renewed
- strut top mounts renewed
- steering gear mounts OK
- steeing column OK
- steering gear pre-tension (tried several values, no change)
- Power steering OK
- every single bolt and nut has been tightened correctly and check at least 10 times the last couple of weeks. So basically the front suspension is almost brand new (the problem occured before renewing the parts as well so it is not due to the new parts)
I just came back from a test without power steering as I thought it could be the cause for this light steering as well. I disconnected the aux belt that drives the PS pump and drove the car like that. The steering was undoubtly very hard to turn but around center it always felt quite light. I think that the stiffer steering due to the lack of PS only occured at about 1/8 rotation in the steering wheel but around center I still get this wandering feel.
Now I guess the last thing may be the steering rack itself that could be worn out (the car is 260000km) but I can't understand that this would cause this behaviour. I for sure have a small play in the steering gear but about 5mm at the steering wheel only. This is still considered normal as far as I've heard. Moreover the weird thing is this extreme sensitivity to road curvature that pulls the steering and the car on one side. This makes the steering wheel turn so it is not just caused by play in the steering gear.
I would think it could be alignment but it's within specs. I have a small amount of neg camber and toe-in at front. I wonder if this could cause that behaviour on uneven or inclined roads. The only alignment setting that is slightly off is the right caster angle that is a bit less than the right one but it's still within spec.
Any idea what else I could try or test? I don't want to change the steering gear just to see that it wasn't the cause of the problem
- tire pressure OK
- alignment OK
- steeing column OK
- Power steering OK
