Originally Posted By: Astro14
In the same sentance, you claim that the forces must be equal and must not be equal. Both statements can't be right...
Yo, cap'n! Have you got a tooth against the Normal Force too?
http://en.wikipedia.org/wiki/Normal_force
What, are we dismantling the whole of physics now?
How large would you want the Normal Force to be? Larger than the weight of the bucket of concrete (I assume a 0 weight cable because I'm a noobster so I can) it's keeping up?
Would you like for the steel cable to coil in on itself and hoist the bucket up to the crane hook on its own?
I don't understand your conundrum.
In fact, while you "feel" the Pseudo force, there is only one force acting - the force that changes your direction...
Well, how about if I used a strong rocket engine to squish you against a rather big asteroid (with lots of mass and, consequently, inertia but still a lot less gravitational acceleration than the moon -> negligible weight).
How fake would you consider the Normal Force stemming from the surface to be then? Really fake, not so fake?
I mean, the Normal Force would only be the result of the asteroid's rather large inertia resisting acceleration by the rocket engine I strapped to your back so you should be fine, right? Inertial forces being fake and all.
remember, we're describing motion here...not static tension of a hanging bucket.
That's right, drag the goal posts with you as go. Can't be too careful, you know!
Don't confuse the issue (or yourself) by using the word "force" ambiguously...stick with the force definition from lessons 1 and 2.
Why? Are you formally declaring the Normal Force to be fake as well?
BTW, you still haven't touched on the other inertial forces I mentioned (drag, lift, thrust, etc.). You know, the ones that exact noticeable acceleration or deceleration.
Newton's second law of motion applies. A force acts on you to continuously change your velocity (direction of motion).
So no force is acting on a styrofoam cup being compressed by the weight of 2000 metres of ocean? Why, just because it isn't going anywhere?
In the case of the bucket there is no NET force - it is static - it is hanging without acceleration....so we're not talking about motion....F=MA. If A=0, then the other side of the equation (F) must also be zero!
Wow! You've entangled yourself quite nicely there; painted yourself in a corner, as it were. You're basically saying that because I'm not hurtling down to the centre of the earth then gravity doesn't exist. Nice one.
This is why the definitions and principles matter so much.
Not really. Just like with software development, there are no such things as all-encompassing and always valid definitions and principles.
It's like saying a constitution will never need amendments after its final draft.
