I should add that in cases like this, a can of starting fluid can come in handy. A good healthy shot into the intake, and it can help getting those cylinders banging away.
Drain the old fuel and add fresh fuel. Drain the oil and replace the oil filter, replace the oil. Pull the injector connectors (disconnect the electrical side of the injectors) and crank it for several seconds to build oil pressure and get oil on everything. Then reconnect and fire it up.
I just did this with a car using the KBB instant cash offer system. It worked out just fine. Had been sitting for 2 years. The dealers are going to wholesale the car and won't care about the trivial stuff. I wouldn't even waste money on a battery, jump start it and drive to one of the dealers that participates in the instant cash offer. (Submit the info to the online cash offer system a few days ahead, they will start calling you, then just take it to the closest one) Leave it running and get the paperwork done!Yes, the intent is for a quick sale. Dealer etc. We realize we won’t be making any money on this car. It’s 180 miles away and really don’t have the inclination to drive 3+ hours multiple times to show the car for a traditional sale.
The old fuel won’t necessarily be a big deal. It could be I suppose. But I’d be more concerned with trying to turn the engine over by hand if you can….
Yeah gas goes bad. But it will often run all the same, fwiw.I pulled a snowblower out of my mom's garage that hasn't been used since 2017. Same gas since 2017. It started on the 3rd pull after a lot of priming to fill the carb back up...
The gas itself smelled awful and the exhaust even worse.
I once had an outboard engine that hadn't been started, perhaps in over 15 years. I dumped the gas out of its remote tank, put in some fresh fuel along with some 2 stroke oil, pumped some fuel to the carb from the tank and pulled the cord, she started right up.I pulled a snowblower out of my mom's garage that hasn't been used since 2017. Same gas since 2017. It started on the 3rd pull after a lot of priming to fill the carb back up...
I did much the same with a older, (1984), Honda generator, and a 1970's Homelite chainsaw. Fresh gas, and several good, hard pulls, and they fired right up.I once had an outboard engine that hadn't been started, perhaps in over 15 years. I dumped the gas out of its remote tank, put in some fresh fuel along with some 2 stroke oil, pumped some fuel to the carb from the tank and pulled the cord, she started right up.
