Starter turning prematurely.
Toronto, Canada
I just replaced a Delco 28MT starter on a Freighliner truck with a Delco rebuilt unit. Now about every tenth start the starter will just spin freely without engaging the flywheel. I do not believe that it is the teeth on the flywheel since there was no such problem at all with the old starter. I will check the teeth again when I take off the starter. My theory is that the solenoid electrical contact is being made a little prematurely before the drive is extended enough to engage the flywheel properly. Have you ever come across this problem before? I am going to take the starter off and get it exchanged under warranty but I felt that I should have the benefit of some BITOG wisdom first.
To add to my post, I did not lubricate the starter drive since the instructions that come with rebuilt starters always tell you not to lubricate the drive. I have been tempted to lubricate in the past but have always figured that the rebuiders caution against lubrication for a specific reason. I am guessing the reason is that if a heavy oil or grease is used it will hinder the free travel of the drive.
Delco rebuilds used to be good, but who knows now where they are outsourced from?
It sounds like a bad starter - the Bendix drive.
