Standby air Cooled Generator
Originally Posted By: Sebastian
I would use that 5W30 oil too.
I don't understand why the specification calls for a 5W30 up to 10° and a 10W30 up to 40° since both oils have the same viscocity when "hot".
The 10w30 and the straight 30 weight are both mineral oil,
The 5-30 is the only synthetic oil listed.
Ok, but that has nothing to do with the temperature range, even more, the 5W30 surely has a better VI than the 10W30 or 30 so it would give better viscocity protection in case the engin temperature over passes 100°C.
I can assure you an air cooled generator going to get a little bit hotter than than 212 degrees. More like 220-230 is fairly normal.
??? That's a major generalization there.
SAE30, 5w30 and 10w30 are all rated as a "30 weight" at 100C.
Which one holds-up better beyond 100C is going to depend on the quality of the formulation, the blend, etc...
Joel
Although the cold isn't a significant issue here in Fl, I use Defy 10w40 in my Miller/Onan powered Bobcat.
For budget option, 5w30 Defy?
