quote:
Originally posted by XS650:
quote:
Originally posted by motorguy222:
Haley is right.Has anyone cut open a used filter and backflushed it with water?
I have,there is a LARGE amount of very fine dirt that will flow from the filtering material.
What's your technique? I have some cut open spread out used filter elements in my garage that I was going to throw away, might as well learn something from them first. They all look clean to the nekkid eye, but I'm sure they are holding some fine cr@p.
The way I do it is,I cut the filter can open.
I keep the filter element intact,I don't cut it at all.
This way you have the WHOLE filter unit/element in one piece.
I then take the filter and put the outlet end on a faucet.A water hose could probably be used also.
I used the kitchen faucet and a small bucket to catch the water that backflushed through the filter element.
Be careful,if you are married,the wife may not need to see this.
If the element you are testing has a relief valve,plug it up some way so that the water must backflush through the element.
Slowly turn on the water,keeping as tight of fit to the water supply as possible and watch for the ooze to begin.
When it does,you should be able to turn the water on a little more.
When you do,you should be able to see a fine black watery goo start to come out of the element.
It is a very fine dirt/sludge that comes out.
While some may say that it wont make a difference,I say any dirt that is filtered out is GOOD for MY engine.
