Originally Posted By: doitmyself
So, after reading your posts, you have not concluded whether or not Stabil does it's intended job of oxidation and corrosion control.
You have demonstrated, however, that if Stabil treated gasoline is left open to evaporate, then a varnish film remains. Therefore, it is reasonable to assume that one should not let their carburators evaporate dry with Stabil treated fuel in them.
You should repeat the test with plain gasoline(a control)as well as with gas treated with other products.
If you find a product that does not result in a varnish layer, then you still have to determine if that product is effective at delaying oxidation and corrosion.
It would be interesting to write each company and ask if their product is designed to prevent varnish residue upon complete evaporation.
Also, I need to learn.....is it common for gas to evaporate out of carburators? Anyone know?
Keep us posted on your results, please. Knock on wood, but using very modest fuel management practices, I have not yet had any E-10 catastrophic failures...knock on wood again.
The other tests are in progress. Too early to know the oxidation results. This may take 1-2 months longer.
As for carb evaporation, my carb has a large bowl vent that allows vapors to escape. Carbs are never air tight by design.
I'm told it takes 6 months for a carb to turn dry. In my case it's much faster, 1-2 months, based on difficulty starting after some inactivity.
Unfortunately, my carb cannot be run dry completely or drained. Based on my results so far, I'm leaning towards no additives or Seafom or TCW3 additives.
