I just bought an Acura MDX, and want to get in a quick oil change at 57k miles, and then I'll get on standard 5k mile OCIs at 60k.
So I hopped in Walmart real quicklastnight to get a jug of Pennzoil Conventional and a Super Tech7317. Once home, I was looking at the filter and discovered that if I stick my finger down through the hole, I can move the cartridge about inside the canister. It's loose. I've never had that from a filter before, and probably won't use it. I don't think the oil/filter are that old anyway, so I'll just keep the current filter on it and just change the oil.
Is this "normal" for a spin-on filter? I've never noticed this movement in anything else I've used before. It's like the cartridge assembly down in the filter isn't properly fixed to the base plate. This is the first Super Tech filter I've purchased.
