I have an hp workstation with 4 -15000 rpm sas drives. Boot up time is not important. Would I really notice the speed difference with an ssd?
I think you mean sata secondary. NVMe is by default ssd only.Recently purchased a NUC with an NVMe primary drive and an SSD secondary; IIRC the SSD transfer rate is 1/6 the NVMe one.
To the OP, yes, an SSD would make the machine faster (and less noisy)
If you're so inclined, SAS SSDs do exist. They're expensive, but when I looked they're not as crazy I expected. Amazon has 1.6gb Dell PowerEdge SAS SSDs for $509, compared with $250 for a 2tb Samsung EVO 870. That's comparing a high end consumer SSD to a full on enterprise grade SAS drive. A 1.9gb Intel enterprise SSD is $400, so that difference isn't drastic either.
SAS SSD future development has pretty much halted since NVMe enterprise SSD came along. The main reason being the performance in NVMe is much better, latency is much lower, and with the right development kit (SPDK/DPDK) you can have near 0% CPU utilization dealing with drive traffic vs a lot of device driver / OS to handle SAS. Most SAS drives development in the future are joint development between competitors to upgrade old server array instead of new server / customers in the cloud. It will go away in a few years for SSD but may stay around for enterprise mechanical drive.
Well if it is good enough for enterprise SSD to replace SAS, it should be a least as good as SCSI based protocols. PCIe itself has CRC and enterprise grade stuff has end to end data protection (can detect if some parts in the middle has been corrupted).I love my PCIe NVMe drives. I also have older AHCI PCIe drives in use(the boot drives in my Mac Pro).
With that said, do you know how data integrity of NVMe over PCIe compares to SCSI based protocols?
Yup, they are built differently depends on how you want it, and cost accordingly as well.Enterprise SSDs can be purchased in "read mostly," "mixed," or "write intensive configurations.
I had to purchase 19Tb of write intensive SSDs for collecting event information from 15000 PCs; I'm thinking they were 800Gb and, IIRC, well above $2KUSD this was a few years ago.
I check the remaining life and the were still above 92%
