Sportwagen at VIR...
Virginia
... with some race cars passing me so turn it up for some awesome racecar noises! Quick run down of the BITOG-related stuff included.
I go with a buddy and his daughter so we are the VW crew! Ran the first 2 sessions of the day in advanced group but there were some race teams testing...IMSA Lambo Trofeo car and some Porsche Cup cars. So fast. The closing speeds were mental and really unnerving so I backed it down to the upper-intermediate group and had a lot more fun not worrying about getting runover. Car did well as usual, no real issues/drama. Uses about ~1/4-1/3 qt of the HPL Euro 5W40/day where day = 4 20-25 min sessions. Oil temps were in the 265-275 F range with cool ambients. Fram Endurance filter didn't implode 🤣 Coolant gauge never moved so that means it stayed under ~235; My 70:30 water to coolant mix + water wetter seems to work well. Tires were kicked at the end...15 days on the Nexen N'Fera Sport R 200 treadwear 245/40/17s...that's about 60 heat cycles which is pretty good. Front left started to look bad after day 1 (some areas on the outer tread where the rubber was worn through to the inner layer. Lots of hard rights at VIR which kills that tire position. I rotated that evening so I could run hard on day 2. Had to swap out f. brake pads as well, right front outer pad was tapered enough to be near the backing plate on the lower forward portion so had to toss on my spares; EBC RP-X. I usually get 3 days out of them (these had 2 + a few K street miles)...I need to start rotating them which should help. The Endless RF650 fluid is amazing, no change in pedal feel ever like I used to get with the Motul RBF600. I may add a catch can in to my modified OEM PCV for this fall's event I'm doing just to keep that oil out of the charge pipes/cooler...my silicone hoses are sweating oil! Ran 93 octane on the first day and on day 2 I splashed in some E85 I brought along for the hell of it - I know I make a touch more power with it as an octane booster based on max speeds. I also ran a can of Liquimoly Speedtec each tand (Toluene) b/c LIQUIMOLY RULES!!! If I had a BITOG sticker I'd run it.
Here are a few highlights (I suggest you adjust it to 1080):
You are my hero! Keep flying your freak flag. What was that BMW your ran down?
E46 M3. Dude is apparently like 80!!! The freak flagship!
Clean crisp shifts. Is that a DCT tranny?
Yes...VW's famed "DSG" - Direct Shift Gearbox. 6 spd. It's so good for this kind of stuff. Gearing is not great, it's econo-gearing on this model...wish 3-4 were a bit lower...it hurts me out of turns where shifting to second isn't quite worth it.
Years ago I was near VIR on business during a weekday and was determined to stop by because I had never seen the place. I come to the gate and a sign says something like "Track closed for private BMW event". I pull up in my 540, give the guard the "hi" sign and he waves me through. It was a M series car 2-day track event. All types of M cars lined up. I drove back to the paddock and talked to some instructors and went to the garage and talked to a mechanic who was doing a brake job on an M6. He pulled a front rotor the size of a man hole cover off, warped as heck. Said those things don't last a full day during these events.
Awesome video, smiling from ear to ear.
Is this your daily driver? I see you hit 142 mph at one point. Amazing!
You are our VW hero! As as the owner of a 17 GTI with a DSG I highly applaud your work. You sure go through a lot of wear items.
Endless is a step up from RBF600. Motul RBF660 has similar characteristics to RF650. I use 660, never had change in pedal feel.
That's what my friends are using. I just heard so much about how great this Endless stuff is I wanted to try it. Did not disappoint
Not really. 15 track days for tires like this is v. good. 3 days for f. pads that coat $265 is also reasonable. Rear pads are roughly double that. Brake fluid is a bleed every event for good measure so about 1/2 a can. The big one I need to lower my cost on is rotor rings. I am looking at a more economical option for next time I need to replace them - getting about 10 days out of them so ~3x pads per ring which seems about right. Vs. street use? Sure it's crazy but for tracking a car that isn't a super light low power thing like a Miata it's not bad to me. I calc ~$275/track day in consumables including fuel, there are folks double that....ouch!
Nice drivin'. Ride them curbs! Are you turning 2:20ish laps?
My PB is a 2:14, couldn't get it this time and best this weekend was a 2:16. My consistent laps were 2:17-2:20 for this event. I have a buddy who got a 2:13 in an awd Sportwagen making less power and only lightly modded, he drives with a bit more "reckless abandon" than me so at some point I'm good with just crusing at this pace and having fun/not dying/crashing my car. Oh yeah, that wagon is totalled from driving like that...no thanks.
