I have installed a spin on filter base that takes a PH8A filter and all is good so far. My concern is that I don't want to restrict flow to the transmission cooler during heavy towing in the heat. I'm thinking of installing a manual three way valve to bypass the filter during hot and heavy towing conditions and filter the ATF only during normal driving.
Does anyone else have a similar setup and have you noticed a difference in fluid temps?
