spin on bypass filter needed
Gillette, WY
i have the head, and i was wondering if anyone knows of a manufacturer that makes a spin on bypass filter with the thread size
1-16un-2b
The head i found i bought 4 of them, becasue i got them new from fleetguard for 5 bucks each.
They are designed for an lf3552 ( im putting a spin on on my transmission too...)
Thanks! SEAN!
Ah-ha!!! You got them off of the liquidator on ebay!! No ..it could have been a coincidense ..but I bid on 4 filter heads and losts
Anyway...if it's a 1-16 thread ..then an Amsoil BE filter is the only bypass filter that I'm aware of that will fit that head. The standard Cummins ff filter will fit it.
Here's what Wix offers in a ff for that xref
Part Number: 57620XE
UPC Number: 765809526204
Principal Application: Extra Efficiency Version Of 57620 - Has Fluted Can * (can use in place of 51607)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper/Glass
Height: 7.000
Outer Diameter Top: 3.690
Outer Diameter Bottom: Closed
Thread Size: 1-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=14/25
Burst Pressure-PSI: 378
Max Flow Rate: 12-15 GPM
Nominal Micro Rating: 14
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.830 2.440 0.225
What's a "fluted can"
No, i work for cummins, so i get...ummm the mine discount, which we sell them to the mines cheaper then we buy them so we can keep the business. The discount equals out to about 55% discount!!!!
So they were cheap!
im needing a BYASS filter for this head. Its a small head, id like to use it for my transmission.
Are those crosses you gave me for the Ams bypass, or for the filter i mentioned?
Thanks!
SEAN!
Amsoil is the only bypass filter for that mount that I'm aware of ...and I looked plenty. That would be a BE90,100,110 from one of the site sponsors.
The filter above (spec's) is a WIX ..and that crosses to your LF3552. It's not anywhere near being considered a bypass filter.
ok, thanks!
Working here at cummins, my filter knowlede, or lack there of is of Fleetguard only, thats what we sell....
Fleetguard makes some better then average filters, but i dont think they are the greatest! thanks again!
SEAN!
