Special Oil for Chrsler Minivan FFV
SE Michigan
Does anyone know what kind of oil Chrysler recommends if using E85 in their FFV Minivans, I just read about this on a E85 Website?
They used to recommend a full synthetic oil that met a specific Mopar spec number, but have since rescinded that recommendation. They do however now tell you to follow the "severe" service schedule if using E-85 more than 50% of the time.
I think it's more about the ethanol washing down past the rings diluting the oil than it is anything to do with the combustion byproducts of the ethanol, which is more benign than gasoline combustion blow-by.
My dad and I both drive FFVs, and both him and I have noticed the oil stays much cleaner running E-85 than it does running gasoline. I've got a tick over 3000 miles on my oil change of Pennzoil Platinum, and it's still so clean it has the slight greenish tint to it yet. My dad runs Mobil 1 in his, and at 5000 miles it's still perfectly golden color. Not a trace of darkening.
Whether that means anything or not is not certain, but running either engine on gasoline for a normal OCI would definitely show considerable darkening of the oil.
I know my Chilton manual for older dodge 4 cyls DOES mention using a special oil if using the old FFV's, which were the methanol ones.
Since then, I haven't heard anything about special oils. Like GT said, I would expect less "dirt" to make it to the oil since less is produced by burning ethanol.
