With Toyota its NGK or Denso only. Typically Toyota installs Denso at the factory. You can use copper type plugs but will need to change them more often. Think about that for a V6 where the rear bank is hard to access.
Hey guy’s, Can I use a different spark plug than what the manufacturer recommend? For example, The manufacturer of my Toyota and Acura recommend Ngk or Denso iridium spark plugs. Will there be a major difference or problem if I install Denso platinum or copper plugs? Thanks
Yes,... if you install copper plugs, then you have to change them out sooner. Both Denso platinum and copper plugs, due to the center electrode diameter being larger than iridium will produce a less efficient combustion than the small diameter iridium tipped plugs.
