I have a small block 350 in my car. Based on casting #'s (3970010) and engine code (V0806TXB) the block is from 1975. The cylinder heads (333882) are 1.94 intake, 1.5 exhaust and match the block. I know these heads are prone to run hot because they are lighter and have a double heat-riser but that is what is there for now. I don't know my compression ratio but I do not believe it is over 9.0:1. The previous owner was running AC Delco R45TS plugs but I was thinking of going down a heat range or two to a R44 or R43 plug. I don't have evidence of detonation but I though a colder plug could be safer. Also, what are thoughts on the extended tip plugs?
