Spark plugs for Westinghouse 2200ixlt
VA
The manual says it has a torch A5RTC, and has a chart that says equivalent are autolite 4914,. Denso 6010,. NGK CR4HJB. Searches for these all the numbers seem to be obscure.
Is there a more readily accessible mainstream plug I can use like a champion y6 or an e3 something? I only have like 10 hours on the machine in 3 years, I have very reliable electrical service. I just want to be prepared and get a couple extra to sit around. TIA.
NGK #7222 (BPR4ES) should work
Bosch #4020 (WR9DP)
It seems that the NGK CR4HJB has been replaced by the CR4HSB (#4695), which is available at Autozone, AAP, and Rock Auto
I swapped my China plug in my Westinghouse gen for a autolite I'll look for plug number tonight it took some digging. I stand corrected I'm running a NGK BPR6HS I bought the autolite for a spare
