Small Engine Spark Plug
Please let me know if they found a way to make their plugs "straight". Almost every one I see has the center electrode off-center. I will not use a crooked plug when NGK knows how to do a good job reliably.
They just work. Don't know what else to say and I haven't seen any defects but I'm not looking at it under a microscope either. Don't use it if you don't like it.
I just eyeball down the center of the electrode and it's obvious if it's centered or not. This has been going on for many years and doesn't seem to be getting better. Having said that, I don't use Champion any more (what's the point?) so the amount that I find / see is significantly less.
Some pics are in this thread but it's much easier to see it in person, difficult to get a good picture. I think if you can't make a circle round (concentric) then what else are you not doing?
They can be bent to center before installing, just like they can be bent to gap. Done. Silly thing to condemn a standard electrode plug over. And it most likely doesn't affect the spark and ignition of gas.
You can't bend the center electrode without breaking it. It's not the ground-strap that's off center.
