A neighbor -a true 'boat guy' from birth- is a Coast Guard instructor.
When Anti-Seize came up, he said, "We put it on everything"
Never had a bad experience with it
Only when it catches on fire while you’re trying to heat the parts, too…Liquid Wrench smells like dispare.
That's easy. Change the plugs more frequently. Something like every 40K or 50K miles.Seriously, what could the OP have done to prevent this?
None, the plug is sealed by a washer/gasket or tapered seat no penetrating fluid is getting by that ditto O2 sensors, the corrosion came from the unsealed combustion side. Notice it was an NGK plug with that does not need anti seize.This topic raises a question in my mind. Which penetrant would be preferable to use on spark plugs if one were to encounter one that doesn't easily break free?
You must not have worked in a shop with a bunch of clowns. Anti seize on the the headband of the grounds guy's hat who would come in to foul our restroom was great sport. He certainly didn't have a good experience with it. On the serious side, all exhaust hardware I work with gets it. Saves a lot of grief down the road.Never had a bad experience with it
I used axle grease for that, don't waste the good stuff on shenanigans!You must not have worked in a shop with a bunch of clowns. Anti seize on the the headband of the grounds guy's hat who would come in to foul our restroom was great sport. He certainly didn't have a good experience with it. On the serious side, all exhaust hardware I work with gets it. Saves a lot of grief down the road.
Is that a real NGK or an ebay knockoff?The moment the spark plug socket goes loose and you realize you’re in for a long sweaty afternoon..........View attachment 214913
I have - a previous “technician” applied too much anti-seize on the sparkplugs of my V70R. They were very difficult to remove. I thought I was stripping the head with the amount of torque it took.Never had a bad experience with it
I had to chase the threads a couple of times to get rid of the excess, before I could install the new plugs. Not the first time this has happened to me.
Anti-seize gets over-used, slathered on there, and makes things worse. Hydro-locks blind bolt holes, gunks up sparkplugs, causes problems.
A little bit, just a little bit, is all you need. Not gobs of the stuff!
I could get on board with 20k on my old Neon, easy peasy, right on top. Those things only like fresh copper plugs anyways.Agree with @slo town. Spark plugs are too inexpensive to risk injuring the head. I change them every 20k on the Volvos.
23 year Navy Veteran....yes. Unless it was dinner time and you're covered in silver and Jim is munching away next to you, and the cook says "shouldn't you guys wash up?" Jim just mutters, "won't matta." You haven't lived....A neighbor -a true 'boat guy' from birth- is a Coast Guard instructor.
