Last week I changed the plugs and wires in my Ranger, the drivers side routing is a little difficult due to the EGR tube going from the exhaust manifold to the EGR valve being so close to the wires. A portion of the tube is wrapped with a material to keep the wires away from the heat, while the lower portion is bare. A few days ago I decided to re-route the wires, as I noticed they were rubbing against the bare part of the tube, I'm glad I checked cause they were all starting to burn through, but I didnt have any arcing or sparking. I bought 3 new wires, and I routed them as best as i could in between the valve cover and the tube.(instead of on the outside of the tube as I had done before) I also used a Mr. Gasket spark plug wire clip to keep them uniform and straight near the firewall. My only concern is, while they arent in a bind, (plenty of slack) one of the wires is touching the valve cover, while one of the wires is touching the EGR tube, its touching the portion that is wrapped with the material. While I doubt the valve cover heat will damage the wire, I'm still concerned about the wire touching the EGR tube. I was thinking of wrapping the whole tube in a few layers of header wrap. I used Napa Mileage Plus wires. Any ideas guys? Thanks
