- Joined
- Oct 26, 2022
- Messages
- 51
I have an Eastern Tool and Equipment (ETQ 950/TG1200) air cooled two stroke generator that is available from a plethora of manufacturers as it’s just a cheap Chinese one but they are all the same basic machine. The owners manual for the specific model I have says to use a NGK BPR6ES spark plug. While reading around the web I found an owners manual under the Champion Power Equipment name and that recommends three different plugs (heat range is different) depending on ambient temperature and use. I also found under the Tail Gator name to use a different plug than the four already talked about. Would it be of any benefit to change the plug according to the temperature or use?
