Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 4,902
Long story short, small phone carriers (100,000 customers or less) were exempt until 2023 from implementing anti-robocalling measures to allow more time for them to update their systems. The FCC decided to move the compliance date to today, June 30th.
A system known as STIR/SKAKEN is used to assign a token for each phone call that only an FCC approved carriers have access to. The receiving carrier then verifies the token and allows the call to go through, otherwise without a token, a non verified phone call wont make it across the network. This system prevents spoofed numbers and ID's that abuse the caller ID protocol and stops spammers because they use fly by night small carriers that cater to overseas spamming operations.
With the FCC moving the compliance date to today, these carriers will have to close shop or update their systems, which would defeat their purpose. Hopefully this stops the majority of spammers because it removes their anonymity and requires traceable numbers / companies to comply with the do not call registry (linked below, sign up).
So if you receive a call from a company, and you are on the do not call registry then you can literally sue them in court. if you are determined enough. Most of the time these companies do not show up and you win a default judgement of $500 the first time and I think up to $10k if they keep calling you.
Hopefully these calls stop completely soon.
https://www.donotcall.gov/register.html
https://arstechnica.com/tech-policy...that-many-robocallers-used-to-evade-blocking/
