From reading BITOG over the years it seems pretty much all name brand oils are good and in general will all get the job done. It all just boils down to whatever you try and end up likeing....then just stick with it. It really seems some really enjoy just switching oils, then conducting a UOA and coming on here to give thier results.
On my fbody, I started using Mobil 1 10w30 and then switched to Mobile 40w. Haven't done any tests but I cant really complain. 130k and still chugging. This includes a few bottles of nitrous run through it, a cam swap at 128k(cam bearings looked great), and a constant beating for over 10years.
So now with the 06 Civic I'm for some reason getting more into what oils to use and curious to find out what each does. I have planned on using Penzoil Platinum but after talking to Frank at auto rx he recommended just sticking with what im doing now and apply a maint dose. Now I am VERY curious to try out Amsoil and see if i can push the oil and AEO filter to 25k. Use the money I save on oil changes on UOA's instead to see the results. Just a little nervous about the intial investment of Amsoil and coming out with negative results. I am also likeing the idea that over the 25k period I will be using alot less oil then the typical 6k OIC.
Amsoil recommends these oils when I put in my car for a parts list. Honda recommends 5w20. Any suggestions?
100% Synthetic 0W-20 Motor Oil
SAE 5W-20 XL Synthetic Motor Oil
SAE 0w30 Synthetic Signature Series Oil
Am I on the wrong track here? Should I still apply the Auto Rx to the amsoil? Is this all even worth it since im not really sure i can even read and understand a UOA report?LOL
