Question-
I will soon be conducting a used oil analysis on an '08 Sebring 2.7l V6. This vehicle is used only for short trips, less than 5 miles daily. When I take my sample should I still take the car out long enough to boil off moisture or should I take the sample cold? Since the engine never gets to operating temp taking it cold should reveal what exactly the oil looks like as it is being pumped through the engine, whereas taking it hot may give a "false-positive" of the oils condition. What would you suggest?
Blackstone Answer-
Thanks for the e-mail. Since your engine doesn't see much highway use, it may indeed be a little deceiving to get a sample after a long run on the highway. Go ahead and get one from a cold engine after normal operation and lets see what shows up. Things might not be bad at all.
Blackstone Answer-
