For those who use 2 stroke oil
http://www.lubegard.com/~/C-238/LUBEGARD+Power+Shield+2+Cycle+Oil+%26+Re-Conditioner+
Quote:
* LXE provides optimum thermal stability. It will not readily break down, even under the most extreme heat and pressure. This is exceptionally important as it allows for unmatched upper cylinder lubrication. Lack of upper cylinder lubrication is the main cause of 2 cycle engine seizures.
* If that isn’t enough, LXE will actually soften old carbon deposits from years of use and storage, allowing deposits to be eliminated through normal combustion.
