hi everyone
1-I have 3 oils what are the best
Mobil 1 0w-40 VI 185 with this datasheet http://www.mobil.com/Saudi_Arabia-English/Lubes/PDS/GLXXENPVLMOMobil_1_New_Life_0W-40.aspx
Shell Helix 0w-40 VI 186 http://www.aljomaihshell.com/ar/pdf/HELIX Ultra.pdf
shell Helix 10w60 VI 174 http://www.epc.shell.com/docs/GPCDOC_GTDS_Shell_Helix_Ultra_Racing_10W-60_%28SN_CF_A3_B4%29_%28en%29_TDS.pdf
this link to calculate VI (to calculate VI for shell 0w-40) http://www.widman.biz/English/Calculators/VI.html
2-If we said the most important physical characterestics is Viscosity Index & synthitec oils better than mineral oil I found mineral oil shell helix 10w30 has VI 161 and semi-synthetic oil castrol magnatec has VI 14. does shell is better
Note: we know the degree of synthitec in semi-synthitec oil is 10%-30% so it may be 10% synthitec and the remainingpercentage is mineral so 10% is synthitec and 90% is mineral if we compare between 10 nad 90 there is a huge different so can we say they are similiar to each other but shell is better because the value of VI 161
shell 10w30 datasheet http://www.epc.shell.com/docs/GPCDOC_Local_TDS_Oman_Shell_Helix_HX5_10W-30_(SL_CF_A2_B2)_(en)_TDS_v2.pdf
castrol 10w-40 datasheet http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/74C44B9DC8D8A1B780257B1600171A91/$File/BPXE-9526XQ.pdf
3-I have crow victoria 2011 imported from USA I read in owner manuaal use 5w-20 but the weather in my area is too hot in summer tempreture is 55c what is better to use:the same viscosity or another one?
thank you
thank you
