Soldering steel?
West Michigan
Looking for thoughts on soldering steel. I have a few different applications but have yet to get anything to stick, regardless of how long I apply heat with my soldering iron.
1. Stainless steel cables. Think bicycle brake and shifter cables. I would LOVE to solder my ends instead of using a crimp cap to keep them from fraying. I've tried solder iron for many minutes as well as a propane torch. Both with and without flux. The solder simply won't stick.
2. Spring. A little specific, this is the steel spring on a Surefire P60 xenon lamp module. Basically I am trying to solder a 5mm yuji high cri LED in place of the xenon bulb. Same as above, using the soldering iron the solder just won't stick to the steel.
Now, I have a "ok" soldering iron that has worked well for basic electronic work for a few years now. Its a Radio Shack brand 40w "pencil" style unit. DO I just need more watts? Based on my experience with the torch I think its not that simple...
Stainless steels are difficult to solder due to the presence of a chromium oxide layer (that's primarily what makes it "stainless"). You need a flux that is appropriate for the material. This requirement also applies for plain steels.
Silver soldering is a better choice.
40W seems low for this job. There are a number of things to consider for a good solder job:
- The parts must come up to temperature before solder can flow and stick. This is difficult for parts with a large heat sink or with an underpowered soldering tool.
- The parts must be clean and grease-free, including finger oils.
- Flux helps tremendously. Most electrical solder has flux in the wire.
- Oxide on the gun tip needs to be removed before using it to solder.
I restore old radios. I have trouble with large heat sinks in the chassis, even with my 100W/140W soldering gun. Sometimes the thin connecting points can give me fits if a number of wires are attached.
I have successfully soldered cable ends on my bicycle before they fray.
hydrochloric acid is a good flux for stainless and nickel steel. Wash off with water.
silver solder is simply amazing.
Rod
Hmmm, I have 96/4 silver-bearing solder. Was using 60/40 rosin-core solder. Would that do it? I suppose its worth a try. If not would the larger iron be enough? Neither of these applications are large heat sinks, I would think.
No, that is a low-temperature lead free solder used in plumbing applications. "Silver solder" or brazing alloy melts at a much higher temperature.
Harris soldering product chart
https://www.harrisproductsgroup.com/~/media/Files/PDF/Requested%20Resources/FillerMetalSelectionChart.pdf
Have used their products for years. Make sure every thing is clean do not touch any soldering surface with bare fingers ( the oil) and if possible tin first.
I'm not sure which part of the video I like the most, the flaming block of wood in one hand, the lit propane torch he's holding between his knees, or him using his folded over t-shirt to grab the hot solder....
What a maroon...
