Originally Posted By: wrcsixeight
Anybody else notice the 2.4 watt number? That rating is in direct sun, aimed directly at the sun, not at an off angle, through windshield glass. The linked panel would struggle to add 1 amp hour to the~ 100 a/h battery in a single winter day. The battery could possibly self discharge more than that.
I doubt 2.4 watts could get a RV sized battery up to gassing voltages. If the RV battery is not unplugged from all parasitic drains like CO detectors, this 2.4 watt panel is a complete waste. The OP will return to dead house batteries.
Some of these panels do not have blocking diodes so they do not drain the battery at night.
You are better off removing the battery, putting it in your garage on a battery tender/minder, or a regular charger on a timer for 15 minutes a day every other day.
The bigger batteries have far lower impedances, so far lower overpotential is necessary to drive current in. It may be about good enough to "maintain", certainly not do anything else. Id imagine that as the battery self discharges due to thermal swings and parasitics, this wouldnt keep up. It just offsets.
