rut roh
I don't know where you're getting the blatant misinformation you're maliciously spewing across the Clark Belt's circumference, but it's definitely not from BITOG, the API, or Chevron Oil Co. Chevron Supreme has been strictly Group II or above since 1996 - or did you miss the "ISOSYN" labeling on the bottles?quote:
Originally posted by Rodbuckler:
Chevron can make the best conventional oil of all time, but this consumer grade Group I garbage oil wasn't it. Buy wisely!
Hi Pabs!quote:
Originally posted by Pablo:
rut roh
Chevron 10W-30 is a bad oil. It coked, varnished, and caused bore and/or ring damage with irreversible oil consumption in my 4.6L Ford. I'm not sure why the previous owners used this unspecified oil.
Use oils that have to pass the rigorous wear and life tests for currently produced autos or trucks. Buy the best oil you can afford, OCI considered of course. Cheap oils and "consumer grade" oils are no bargain.
So your engine has "irreversible oil consumption" and "bore and/or ring damage" and you running Syn for 20k fixed it all ?quote:
This engine runs like a dream come true. But it took 20K miles of synthetic to clean up the rings and bring the oil consumption down after the Chevron 10W-30 garbage oil. Chevron can make the best conventional oil of all time, but this consumer grade Group I garbage oil wasn't it. Buy wisely!
quote:
quote:
No way! This engine runs like a dream come true.
Ghetto fabulous, Let see if I got this straight.... Chevron "caused bore and/or ring damage with irreversible oil consumption". Now without ever taking the motor apart how do you know Chevron the damage bores and rings? How did those damaged bores and rings fix themselves? Do you even have a clue what you are talking about?quote:
I talked with the previous owners at length. This was an I-95 commuter car that was very well maintained. It looks, runs, and drives like new. All fluids were fresh when I bought it. When they hit 1qt/500miles oil consumption I think they decided to sell it. I have put 33K miles on it and it runs best ever.
You had an lengthy conversation with the seller and he told you it was "VERY well maintained". You make the seller sound real honest. cause only a fool would knowingly buy a vehicle that burns a qt in 500 miles. You don't suppose the seller creditability was shot when he left the part out about it burns a qt in 500 miles do ya?
Sounds to me like your tripping over your own words playing anti Chevron keyboard commando wrench.
No way! This engine runs like a dream come true. But it took 20K miles of synthetic to clean up the rings and bring the oil consumption down after the Chevron 10W-30 garbage oil. Chevron can make the best conventional oil of all time, but this consumer grade Group I garbage oil wasn't it. Buy wisely!I thought your initial post said that the oil consumption was "irreversible"? If so, how is it that running a different brand of oil "reversed" it?
I suspect that there was probably some coking and build up, but leaving the previous oil in too long is the most likely culprit, not the specific brand.
It is interesting that the 10w30 datasheet doesn't list ISOSYN like the others.quote:
Now look up the product data sheets here:
http://www.chevrondelo.com/
Search for Supreme
10W-30 sheet is CPS220155 and others.
It does not mention ISOSYN anywhere. Don't use this oil when the 5W-30 is probably sitting there next to it on the shelf for the same price.
5W-20 and 5W-30 sheet is CPS220002 and others.
It specifically mentions ISOSYN as the basestock, as is also used in the excellent Delo 400 10W-30 and 15W-40 oils.
Hi,quote:
Originally posted by 427Z06:
Thanks for sharing Bill. But that still doesn't prove what percentage of Chevron Supreme 10w30 is made with ISOSYN. Could be 51% ISOSYN and 49% Grp I/I+. Given that some producers use 10% Grp III in there blends and have no qualms about calling them synthetic blends, it's not a far stretch by any imagination.
