So... is GC really so shear stable?
Fairfield County, CT
Check this out; let me know if I've made any errors...
For the first two cars I'm using a VOA viscosity of 65.9 (which is the average of 65.8, 65.8, 65.9, and 66.2, gathered from 4 Blackstone virgin reports)
And for the third (Patman's sister's car) I'm using Patman's VOA viscosity of 12.2. Patman, are those viscosities from the same lab? (Wearcheck?)
code:
car miles UOA visc %visc loss
Toyota Sienna 4648 62.0 5.9
Honda Civic b16a 5279 62.8 4.7
Honda Civic 5500 11.5 5.7
Hmmm...
[ October 06, 2003, 10:49 PM: Message edited by: quadrun1 ]
The only way to really judge is to compare the VOA vis of the SAME oil you're doing the UOA on, not an average vis from a bunch of different VOAs. We'll be finding out how well this oil has held up in my Chrysler shortly.
FWIW, I think any multigrade oil is going to shear some. "Shear stability" is a relative thing, and relatively speaking, the GC seems to be shear stable.
How 'bout these shear numbers I figured a few weeks ago?
Or these recalculated shear numbers I figured the next day? (I threw out the worst example.)
Yes, I'd say EC 0W-30 looks very good too.
Almost as good as M1 0W-40 ...
Yes, both the virgin sample I sent and the UOA on my sister's car were from Wearcheck. The one thing though is that the oil I put in my sister's car was from a different batch than the VOA oil, so it is possible her oil was slightly different in viscosity. Also remember, it was her first run with GC, so there is a little bit of the thinner M1 mixed in there. Her second UOA (which I'll have in a couple of weeks) will be the better one to see for viscosity. And my own UOA (due next week) will be good too, since before I put in the GC I have now, I ran a 3L rinse cycle to try and get close to 100% GC in my engine for this run. And the batch in my car is the same as the VOA too.
Eiron,
You just don't give up do you?
Well, neither do "we," so here's to healthy and collegial competition.
[ October 07, 2003, 01:08 PM: Message edited by: pscholte ]
There are some good M1 numbers too!
M1 0W-40 in G-Man's Olds minivan (4200 miles) thinned only about 1%
After 5,000 miles in an Audi S4 twin-turbo and also after 5K in an Audi 1.8T, M1 0W-40 thinned about 6%.
In the S4, the M1 0W-40 wear numbers were about that same as Amsoil S2K.
I think it's a close call, these are both very good oils!
What we really need to see is someone run 2 intervals with 0w40 M1, then two intervals with GC 0w30, in the same engine, in order to see the behavior of the two.
