Quote:
This gets my vote as the all-time most dufus thread on BITOG.
Worse than the few GIII 0w30 diatribes we had?
Quote:
Pennzoil Platinum 10W30 SM.
All the others were as described.
Quote:
So? What myth did THAT experiment dispel?
Quote:
And what would the cP rating be of 0W20 Mobil 1, or even 5W20? Would you expect thinner? Or is 15 or 20 below so cold that nothing will stand up to it?
Quote:
PS, I don't DO crack, I do![]()
Quote:
Since the W spec is just a maximum viscosity at a specific temp, can't a 0w also meet the 10w spec and be correcly labled as a 10w if the manufacturer chooses?
Quote:
I would suggest something is wrong with the test. The viscosity of the oil at 0F or -15C or so will have nothing to do with being a synthetic or non synthetic. Before I went to bed last night I put a 0w20 Pennzoil Platinum, 0w30 Petrocan, and 0w30 Tech 2000 in the freezer. Just checked them, and they are all sloshy and I could easily use any of them to change oil right now. No pour problem as one would expect. My suspicion is that the slosh test is quite sensitive to how full the bottle is. Would likely be better to turn each one upside down and time how long it takes to empty
Quote:
Code:
Temp Castrol Mobil 1 Mobil 1 Mobil 1 Mobil 1 Mobil 1
F Syntec
0w-30 0w-40 0w-30 5w30 10w-30 5w-20
Vi 167 187 169 169 147 163
100C 12.2 14.3 11 11.3 10 8.8
40C 72 80 63.1 64.8 62 48.3
cSt
-40 28357.7 19743.0 22092.0 23154.0 39117.0 17893.0
-30 14234.7 10603.0 11202.0 11734.0 18230.0 8925.0
-20 7591.9 5998.0 6032.0 6314.0 9119.0 4745.0
-10 4278.2 3558.0 3430.0 3588.0 4863.0 2672.0
0 2527.6 2199.0 2044.0 2136.0 2739.0 1581.0
10 1560.7 1412.0 1273.0 1329.0 1623.0 979.0
